gabe_1981
#1 Posted : Thursday, June 28, 2012 3:56:52 PM(UTC)
gabe_1981
I'm stumped ... The bottom door stays open an inch ... I switch the bottom door with the top door and same thing ... Top door closes and bottom door stays open an inch ... Lookin and the recieving brakets on the top and bottom they both look the same ... nothin broken or out of place ... What am I missing
#2 Posted : Friday, June 29, 2012 4:37:37 PM(UTC)
Hi gabe1981,
I can see only two possibilities in such situation: slightly bend oven door frame or dislodged and/or damaged hinge receivers.
gabe_1981
#3 Posted : Saturday, October 27, 2012 10:36:43 PM(UTC)
gabe_1981
Gene, Thank you for the reply ... Funny story but I way over thought this one ... The hinges and recieving brackets were still good ... I couldnt tell at first but the cleaning lady cleaned the oven the day before and removed the bottom plate ... when she put it back in she didnt push it back in place ... at a glance you couldnt tell it was out of place ... It sat out just far enough to jam the door ... Again Thank you for all your help
richappy
#4 Posted : Monday, October 29, 2012 12:44:08 AM(UTC)
richappy
To put the door back properly, you must move the hing lock tab away from the door, then, with a screwdriver, pull the door hing back, then slip the door lock tab in place to lock the hing in place, then you can put the door back in properly. The owners manual helps for this.
Oven door will not close (Oven Repair (including Ranges and Cooktops))
by Steve Arthur 11/9/2010 11:32:38 AM(UTC)
Jenn Air oven door will not close (Oven Repair (including Ranges and Cooktops))
by embdenb 9/3/2009 10:48:19 AM(UTC)
