pennshaq
#1 Posted : Friday, April 10, 2009 6:53:43 AM(UTC)
pennshaq
I have an Amana ACF3325A gas range and the burners or oven will not turn on. I turn the knobs to "light" and the igniter does not click like it is trying to spark. The burners will ignite when I light them with a match. Also, I am getting electricity at the oven because the clock, oven light and other electrical parts are working. This tells me it is probably the spark module. However, does the spark module also control the ignition for the oven? If not, is there something else I need to look for?
#2 Posted : Friday, April 10, 2009 5:41:07 PM(UTC)
The spark module for the surface burners has to be replaced. No doubt about it. About the oven - are both Bake and Broil not working or just one of them?
- The part number for the spark module is AP4041378
pennshaq
#3 Posted : Sunday, April 12, 2009 6:55:58 AM(UTC)
pennshaq
Neither Bake or Broil are working.
#4 Posted : Monday, April 13, 2009 12:31:22 PM(UTC)
Check for 120VAC to the Bake and the Broil igniters while the control call for Bake and Broil. If there is no proper power then check for continuity Bake and Broil parts of the gas valve. Post the results.
pennshaq
#5 Posted : Monday, April 13, 2009 7:08:50 PM(UTC)
pennshaq
The fog of stupidity has finally lifted and the Bake and Broil are working, I was just not allowing enough time forthe oven to warm up. The only thing that appears broken is the spark module which I can switch out. Thanks for your help.
#6 Posted : Tuesday, April 14, 2009 7:54:22 PM(UTC)
You are welcome. I'm glad it was that simple.
Guest (7)
