FGMO205KFA Frigidaire Built-In Microwave Replaced Magnatron, then Transformer, then Capacitor Assy - per AppliancePartsPros and still no heat.
Groups: APP Team
Hi.
Please provide complete model number and detailed problem description.
Simon.
Simon. Frigidaire Built-in Microwave - Model # FGMO205KFA Everything works - except no heat. Replaced magnatron ((AP4433505), then transformer (AP4434118), then capacitor assy (AP4299471) - per AppliancePartsPros sales dept. Still no heat. Transformer does get warm on top after 2 minute cycle trying to test heat water. Sales dept suggested contacting tech in forum for help.
Groups: APP Team
Hi.
Disconnect the connector from the PRIMARY winding of the hi-voltage transformer. Using the multimeter check if there is 120VAC across this contacts when the m/w is started.
If the correct voltage is present and you replaced transformer, capacitor and magnetron - check the diod and all wiring according the diagram.
Post the results.
Simon.
works now - thanks - love you guys
Groups: APP Team
You are welcome. What was the problem?
Simon.
