2 Pages12>
Kaiden
#1 Posted : Monday, October 15, 2012 11:34:09 AM(UTC)
Kaiden
My microwave was performing correctly except for "no heat." I troubleshot the problem to a thermostat (#115 on this website's interior diagram). After installing the new part, the microwave no longer has a display. I do have the 110 voltage. The original part had 150/0 on the underside. The new part says 40/56. This was a genuine renewal part from GE and am not sure if it is a correct replacement. Anyone experience this?
Simon / APP Team
#2 Posted : Monday, October 15, 2012 2:43:05 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
This is the part you need Part number: WB21X10148
Check the 20amp fuse, magnetron and cavity thermostats.
Jump the thermostat in question to check if that is the only problem.
Post the results.
Simon.
Kaiden
#3 Posted : Monday, October 15, 2012 3:42:13 PM(UTC)
Kaiden
Hi Simon and thank you for your response. I was wondering, how did you identify this part? The picture below is from the parts list and item #115 is the part I found to be bad. I don't mind getting the part you listed but I just didn't see it in the drawing.
GE WB27X10932 Thermostat - AppliancePartsPros.com
UserPostedImage
When t-shooting, I found the transformer was not getting the 110vac. When I routed 110v straight to the transformer, the microwave heated up the glass of water. I found the thermostat to be a short. I will go ahead and order the part you mentioned if that is what I SHOULD have ordered instead of what the drawing listed.
Thanks again, Simon.
Simon / APP Team
#4 Posted : Monday, October 15, 2012 4:19:30 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
What was the original symptoms?
The reason the transformer isn't getting 120VAC could be bad door switches in the first place or bad control board or open cavity safety thermostat.Put back the old thermostat and run the tests.
Post the results.
Simon.
Kaiden
#5 Posted : Monday, October 15, 2012 5:26:23 PM(UTC)
Kaiden
The original problem was "no heat." I checked all the door switches and values were "infinite" with door open and "short" with door closed. I checked the primary and redundant of the transformer and values were correct per the troubleshooting steps.
The diode and HV cap checked good also. I called the 1-877-477-7278 and told the rep which part (per the diagram/drawing) I was looking for. She said the part I received was correct and is an acceptable replacement since the original part is no longer manufactured.
I actually received the part through my local appliance parts store and it is the exact same part number as this website. I had read on a different search that 150/0 was the thermostat range. Not sure why the new part has 40/56.
Simon / APP Team
#6 Posted : Monday, October 15, 2012 10:39:35 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Is the old 150/0 thermostat open? If it is jump it and check if the m/w works.
The part number I posted is identical to the magnetron limit thermostat.
The 40/56 thermostat is normally open and it's a hood thermostat, not turning off power to the hi-side transformer.
Thank you.
Simon.
Kaiden
#7 Posted : Tuesday, October 16, 2012 9:32:10 AM(UTC)
Kaiden
Hello Simon. It's a short.
Simon / APP Team
#8 Posted : Tuesday, October 16, 2012 1:30:48 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi, Kaiden.
Please be more specific on "It's a short".
Did you try to jump the thermostat #110?
Simon.
Kaiden
#9 Posted : Tuesday, October 16, 2012 3:06:42 PM(UTC)
Kaiden
Hi Simon.
TCO #115 is a short (0.2 ohms). I still jumpered it per your instructions but same status: everything works yet no heat.
TCO #110 reads infinite. When this is jumpered, the fan starts running as soon as I plug in the 110v.
Simon / APP Team
#10 Posted : Tuesday, October 16, 2012 4:04:37 PM(UTC)
Simon / APP Team
Groups: APP Team
That means that those two thermostats are OK.
Let's do the t/s again.
When you program the control and start the m/w does the light, turn table and fan turns on, clock is counting down?
Or only clock is counting?
Simon.
Guest (6)
2 Pages12>
