Need help to install a replacement bottom front door gasket - have new one but see no way to attach it or install it on either the plastic shield or the frame of the door - please advise Thank you
Unfortunately this is beyond my expertise.
Maybe somebody else on the forum can help you better.
if this is a clearish strip about 2" wide +width of door .you have to remove bottom cover +door .the old one slides off +new one slides on .it only fits properly one way ,check how old one fits .
