benlomand
#1 Posted : Friday, October 12, 2012 4:45:34 AM(UTC)
benlomand
Greetings,
Yesterday my otherwise functional GE HydroWave washer became unbalanced and vibrated to a stop before I could get to it.
Now the machine will not operate, has no indicator lights, just like I said. Dead.
I've read about a neutral wire fuse in the harness. Sounds like a good bet for me an electrician. What say pros before I tear into this project?
P.S.
I tried the error code reset, don't help.
I tried to put in in the service mode, nothing lights.
I have power at the receptacle.
Thanks for any help on this matter.
Simon / APP Team
#2 Posted : Friday, October 12, 2012 1:03:41 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
The fuse you mentioned controls the power to the motor inverter board. You still should have power to the main control and water inlet valve.
Check if there is 120VAC to the main board between RB and WR. If the correct voltage present - the board is bad.
No voltage - check the filter Part number: WH12X10408
benlomand
#3 Posted : Friday, October 12, 2012 2:20:53 PM(UTC)
benlomand
Hey thanks Simon. I managed to get that far in determining the cause, but have not actually checked out the filter yet.
I have no power at the board, all points to the filter as you mentioned. I'll drop a response when I figure this puppy out.
Simon / APP Team
#4 Posted : Friday, October 12, 2012 3:32:45 PM(UTC)
Simon / APP Team
Groups: APP Team
You are welcome.
Good luck.
Simon.
benlomand
#5 Posted : Sunday, October 21, 2012 11:05:08 AM(UTC)
benlomand
Simon,
After some digging, my wife found that we had wisely extended our warranty when we bought the machine.
I called and a service man made it out by the end of the week. He immediate suspected the motor, I suggested the filter.
Come to find out, the filter connector to the AC supply was not fully inserted which of course solved the loss of power problem, but when the tech hooked up the motor, still no go. He changed the motor and was on his way.
So, lesson learned? Not really. The machine worked fine for two years then after a particularly violent vibration episode, it was done.
Interestingly, the motor according to name plate is wired three phase. The sophisticated electronics in these household appliances.....I'm not so sure that is a good idea.
Oh well. Thanks for your help.
Simon / APP Team
#6 Posted : Monday, October 22, 2012 7:50:45 AM(UTC)
Simon / APP Team
Groups: APP Team
You are welcome.
Simon.
