dmikel12
#1 Posted : 12 years ago
dmikel12
I have an LG dle5977w dryer . All the sudden my dryer stopped heating up and the cooling light was stuck on the instrument panel. It's onlu blowing out cold air to the outside duct. it's 5 years old , so the first thing I assumed it was the heating element. So I performed a continuity test on the heating element part number 5301el1001a and for the most part I get sound coming from my tester but one spot. I'm not even sure I'm suppossed to be getting a reading from this one spot though. If you look at the part on the left side there are 3 areas where the wires plug into. I get sound on the first 3 wires which are yellow, blue, and red. Then the wires go back to the middle part of the element where there are 1 red wire and 1 white this is the part that has no continuity then the third set in the back has the same 1 red 1 white wire but this area has sound. Keep in mind there are know wires hooked up when I perform this sound test. If it's not the heating element then what other areas could I try and troubleshoot? Appreciate some help on this. Thanks
#2 Posted : 12 years ago
Perform the troubleshooting as described in the attached file and post the results.
Here are the breakdown diagrams and Parts for LG DLE5977W Dryer - AppliancePartsPros.com
P.S. You have to remove all wires from the part being tested for continuity prior to the test.
File Attachment(s):
DLE59xx - not heating.doc (183kb) downloaded 9 time(s).
