du1055f lite is blinking and will not start. I check heating ele. should read 10 to 30 ohms it shows 9 ohms.fuse is good,temp switch is good.Need help
What light is blinking? Clean?
Did you check the hi limit thermostat?
Hi, I check one thermostat on the bottom of the tub it was closed.
Thanks,I will reistall the washer and try it agin.
