rsuarez
#1 Posted : Saturday, October 6, 2012 10:05:44 AM(UTC)
rsuarez
Microwave Suddenly stopped heating and plate stopped turning. Light comes on and timer counts down but no heat and plate wont turn. Both occurred at the same time.
Jenn Air JMC8130DDS
Manufactured July 2005
timg49
#2 Posted : Tuesday, October 16, 2012 12:33:01 PM(UTC)
timg49
I had the same problem. If you search the internet, you can find some tutorials on things to look for.
This youtube video helped me fix my problem. :)
How to fix microwave that counts down but does not heat or turn on. Door Sensor Switch. - YouTube
appliance dude
#3 Posted : Saturday, October 20, 2012 6:24:47 PM(UTC)
appliance dude
Sounds like one of your door interlock switches went out.
Darrell086
#4 Posted : Wednesday, March 26, 2014 6:57:35 PM(UTC)
Darrell086
As appliance dude said most likely the interlock switches. Same symptoms on mine. However, my switches were all good but the wire to the switch burned up causing the same symptoms. Now I just need to find out why the wire was fried. Interestingly enough, it was the left side of the microwave where there is only one switch, (right side has three) and I was able to connect the two wires together and bi-pass the switch to test the microwave. Microwave worked like a champ. Replacing the switches are easy on this model as you only need to remove the top cover of the microwave to gain access to the switches.
