camliv
#1 Posted : Sunday, September 30, 2012 6:40:11 PM(UTC)
camliv
:( Oven Does Not Heat But Elements Are Good. Everything Else Seems To Be Fine .what Could Cause This.
#2 Posted : Monday, October 1, 2012 2:01:54 AM(UTC)
Replacement parts for Frigidaire FEF379ACK Frigidaire/electric Range | AppliancePartsPros.com
Here is the wiring diagram
http://manuals.frigidaire.com/p...pringfield/316255354.pdf
I am assuming that the stove top elements heat OK.
Unplug the unit and check the wiring from the terminal stip to the control board and then from the control board to the elements.
If all OK then odds are that the clock (Item 20 in Section 1) is shot.
You will probably also need a new overlay.
Frigidaire oven does not heat (Oven Repair (including Ranges and Cooktops))
by camliv 9/30/2012 6:35:43 PM(UTC)
