cfalter
#1 Posted : Saturday, September 29, 2012 4:34:50 PM(UTC)
cfalter
Hello, my kenmore dryer will not heat I have replaced the heating element, hi-lo thermostat, thermal cut off, thermostat, thermal fuse, moisture sensor, and dryer still will not heat. Any suggestions on what to do next?:confused::confused::confused::confused:
#2 Posted : Sunday, September 30, 2012 1:31:52 AM(UTC)
Check the power.
The heating element needs 240 volts.
Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker.
Check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
Do this with the heater off and on.
cfalter
#3 Posted : Wednesday, October 10, 2012 7:29:57 AM(UTC)
cfalter
ok checked all power. One line in the cord was bad so I replaced it all power is good and dryer still will not heat! Could it be the temperature switch, or the control board??? I am ready to throw this dryer out and get a new one!! Any suggestions ??
Kenmore Dryer Will Not Heat After Replacing Everything (Dryer Repair)
by jlewis57 10/1/2014 12:28:50 PM(UTC)
Kenmore Dryer will not heat but the drum runs (Dryer Repair)
by asirota1 3/25/2013 8:33:52 AM(UTC)
Kenmore dryer will not heat on second cycle (Dryer Repair)
by Jim G42 7/15/2012 12:18:17 PM(UTC)
Kenmore Dryer Will not heat (Dryer Repair)
by ajb1010 5/21/2012 2:36:03 PM(UTC)
Kenmore dryer will not heat (Dryer Repair)
by saw3c 5/18/2010 9:48:06 AM(UTC)
Kenmore Dryer Will Not Heat Up (Dryer Repair)
by mastaone 11/8/2009 12:44:09 PM(UTC)
by vikingboy 9/25/2009 1:04:15 PM(UTC)
Kenmore dryer will not heat.3 weeks-- my wife is mad (Dryer Repair)
by topagent 7/31/2009 12:51:43 PM(UTC)
by lpennock 5/10/2009 3:56:08 PM(UTC)
Kenmore Dryer will not heat (Dryer Repair)
by T.A.M. 2/9/2009 5:29:54 PM(UTC)
