mekon
#1 Posted : Thursday, September 27, 2012 11:00:27 AM(UTC)
mekon
My maytag washer (2 belt-pulley system) won't spin and the main belt that connects to the center flywheel on the bottom is not turning and smoking. From what I see, that main flywheel won't turn more than 1/2 turn before it gets jammed, stopping the belts from turning and no amount of physical pressure and turn it (clockwise), however it does turn freely all day in the counterclockwise/wrong direction by hand.
The belts starts smoking under the motor @ the double pulley. From what I've seen online it's suggested that I replace a metal liner sleave (part #211130) and the mounting stem rpr. kit (part #6-2095720) with spanner (#22038313). Does this sound right? Do you use any special lubricant to lube any of these parts? thanks
Simon / APP Team
#2 Posted : Thursday, September 27, 2012 12:22:22 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Most likely the tub bearing kit should be replaced Part number: 6-2040130
Along with it replace the mounting stem kit
Part number: 6-2095720
You will need the spanner ranch Part number: 22038313
Don't forget to replace the belts.
Here are the breakdown diagram and Replacement parts for Maytag LSG7806AAE STACKED LAUNDRY- GAS | AppliancePartsPros.com
Good luck.
Simon.
mekon
#3 Posted : Friday, September 28, 2012 9:04:09 AM(UTC)
mekon
Is there any potential brake system issue with this since the bottom flywheel which controls the agitator won't continue to turn more than 1/2 rev. clockwise until it stops dead. Is there any way to test if this is a/the problem.
thanks.
Simon / APP Team
#4 Posted : Friday, September 28, 2012 9:37:40 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Most likely it's the bearings and the way to check it is to take it a part.
Simon.
