25 Pages«<1516171819>»
#161 Posted : Thursday, September 27, 2012 10:39:53 AM(UTC)
Originally Posted by: Jonah5 Go to Quoted Post
Hi I've got a kenmore elite fridge whose icemaker stopped 3-4 yrs ago and been making ice manually since using ice trays! Anyway that's getting old and want to fix it finally.. It just happened that my old fridge in the garage has the exact same icemaker (which still works) so I tried replacing it with that, but still no ice made. As for the lights, with door open and left flapper closed, LED lights solid. With flapper open/ light blocked, the LED alternates 2 flashes every couple seconds. With freezer door light off (using switch) the LED is off. Based on what I've read (I read this whole post-very informative, by the way) this lighting pattern seems normal for the infrared system. Is this correct? Also, when I flip the infrared switch off (on right side) the LED blinks continuously (should the LED be off when the switch is off? Water fill tube appears to be clear and the door water dispenser works fine. Any ideas? Thanks!
What is the complete model numbers of the kitchen refrigerator and the refrigerator in the garage?
#162 Posted : Thursday, September 27, 2012 10:49:51 AM(UTC)
Originally Posted by: amp0 Go to Quoted Post
I have a KitchenAid KSRK22ILSS02. The ice maker does nothing. I jumpered the T and H points and the motor does not move and the tray does not heat up. I verified 115V at the ice maker connector and I verified continuity in the wiring harness.
I replaced the motor module (W10190935) but the results are the same. Any ideas on what to try next?
Thanks!
Open the freezer door. Make sure the on-off switch on the right side is on. Push in the flipper on the left side and watch the status LED on the right side. Post the results.
Here are the breakdown diagrams and Replacement parts for Whirlpool KSRK22ILSS02 SIDE-BY-SIDE REFRIGERATOR | AppliancePartsPros.com
Jonah5
#163 Posted : Thursday, September 27, 2012 11:56:25 AM(UTC)
Jonah5
Kitchen fridge: kenmore elite 106.53709201
Garage: whirlpool ec3jhaxrs01
#164 Posted : Thursday, September 27, 2012 12:03:33 PM(UTC)
Perform the test as described in the attached file and post the results.
File Attachment(s):
In door ice system - component diagnostics.doc (167kb) downloaded 29 time(s).
amp0
#165 Posted : Thursday, September 27, 2012 2:43:50 PM(UTC)
amp0
Sorry, I forgot to mention I did the optical diagnostics and it was OK. With the flipper NOT pushed in I get the 2 pulses. With it pushed in the LED is on solid.
Jonah5
#166 Posted : Thursday, September 27, 2012 6:52:32 PM(UTC)
Jonah5
Hi Gene. Performed the diagnostic test but couldn't get a harvest to initiate. Checked voltage of IM and it was normal. Replaced the garage IM with the original, same results: no harvest, normal voltage getting through. I also tried the other jumper tests and couldn't get a response on either ice maker. Any ideas? I know that the garage IM works, but all tests so far have been without response. Any chance the optics are bad?
Jonah5
#167 Posted : Thursday, September 27, 2012 7:33:01 PM(UTC)
Jonah5
Well, after all that testing, with both IMs, I realized that this whole time the bale switch was in the OFF position! Sheeeesh! Anyway, redid test with the replacement IM (garage) and yes, the harvest initiated, finished and water dispensed. Checked lighting pattern, and only heard 3 beeps, but no light. Ran out of time, so for now I put it all back together and hope that the bale switch was the culprit for the garage IM not working.. If still no ice, I'll be back to try to diagnose some more. Thanks so far for your help, Gene!
#168 Posted : Friday, September 28, 2012 6:44:50 PM(UTC)
Run the test as described in the previously posted attachment. Post the results.
#169 Posted : Friday, September 28, 2012 6:48:11 PM(UTC)
You are welcome Jonah. This switch off is also very common with brand new ice makers. Hopefully it will fix the problem.
amp0
#170 Posted : Friday, September 28, 2012 7:19:21 PM(UTC)
amp0
Hi Gene,
The results of the component diagnostics test are in my original post. With the T and H points jumpered, the motor does not run and the tray does not heat up. Looking for ideas on what to try next.
Thanks,
Andy
Guest (10)
