jetdoc
#1 Posted : Wednesday, September 12, 2012 5:43:54 AM(UTC)
jetdoc
We have a double wall unit Jenn Air range....for a while now the lower unit would show a 'Fr' fault when turned on. The upper one worked fine until recently.
About a week ago it seemed to be taking a long time for the oven to get to pre heat selected temps..but didn't pay a lot of attention to it. Then this morning when trying to use upper oven we selected the temp and it just showed 100 degrees and never got hot....I tried the broiler and same thing, didn't work.
So now we have two probs, 'Fr' fault on lower unit and upper one oven and broiler do not work.
Any help? I think Fr means a circuit board? Thanks in advance.
Simon / APP Team
#2 Posted : Wednesday, September 12, 2012 9:10:35 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Please provide the complete model number of the oven.
Simon.
jetdoc
#3 Posted : Wednesday, September 12, 2012 4:08:47 PM(UTC)
jetdoc
Hey, ok...at work, will later this evening when I get home.
jetdoc
#4 Posted : Wednesday, September 12, 2012 7:19:41 PM(UTC)
jetdoc
Ok here it is.....
WW 274308 is the model number
Simon / APP Team
#5 Posted : Thursday, September 13, 2012 2:06:38 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
To take care of the upper oven problem you need to replace the upper relay board Part number: 74006612
For the lower oven first check the resistance of the oven sensor. With the multimeter set to 10 Kohm at room temperature normal reading about 1100 ohm. if the sensor checks OK - replace the lower oven relay board
Part number: 12001914
Oven sensor Part number: 12001656
Here are the breakdown diagrams and Replacement parts for Jenn-Air WW27430B WALLOVEN- S/C ELE | AppliancePartsPros.com
Post the results.
Simon.
jetdoc
#6 Posted : Thursday, September 13, 2012 2:44:36 PM(UTC)
jetdoc
Wow, thank you so much Simon..I will let you know the results...
jetdoc
#7 Posted : Tuesday, September 18, 2012 4:12:15 AM(UTC)
jetdoc
Ordered the upper board, not sure where its is located...do I have to pull oven out?
The lower, yes it needs a new board as well, the element test ok.
So any help on the location of board would be great.
Simon / APP Team
#8 Posted : Tuesday, September 18, 2012 9:14:07 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Most likely you should remove the oven and open the top. The relay boards are on the side walls (wall). The upper board has more relays in it.
Simon.
Guest
#9 Posted : Friday, August 19, 2022 6:39:54 PM(UTC)
Guest
Groups:
I have a older double stack Jenn air wall oven... When the breaker is turned on the oven starts automatically and does not regulate temperature... You cannot shut it off... Heats to over 650 and beeps because it is over heating... The lower oven functions as designed
ThatGuy
#10 Posted : Sunday, August 21, 2022 5:50:50 AM(UTC)
ThatGuy
Its a stuck relay either on the main control board or relay board if it has one. I don't know because you didn't provide a model number. You'll need a new board or a board repair.
