See the attachment for the tech sheet as I do not think the link I included earlier still works.
Here are the parts
Replacement parts for Kenmore 11063942101 | AppliancePartsPros.comSears like to keep parts breakdowns in house but if you go to their parts site you can get the breakdowns. The relays are in the control console.
[COLOR="Blue"]Where do I go from here?[/COLOR]
I would check the power to the unit. If you do not have 240 volts everything will run except the heater.
Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker.
Check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
Do this with the heater off and on.
[COLOR="Red"]
Be careful as 240 volts is lethal !!![/COLOR]
This may be a jod for a pro if you have no electrical experience!!
If the power is good then you will need a meter
I would suggest you purchase a one. You can get a decent digital multimeter for under $20.00. You do not need fancy though it is nice if the leads are a couple feet long.
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
