miklik
#1 Posted : Thursday, August 30, 2012 12:18:10 PM(UTC)
miklik
Dishwasher worked fine last night but today nothing. Switched the DW plug with the disposal and the disposal stills works in other plug. Rotating the dial nothing happens. No humming or clicking from the dishwasher. What should I check first.
#2 Posted : Thursday, August 30, 2012 2:50:01 PM(UTC)
Remove the bottom panel. Remove the junction box cover on the right side under the dishwasher and check the power cord connections to the dishwasher wires.
Here are the breakdown diagrams and Replacement parts for General Electric HDA3400G00WW Dishwasher | AppliancePartsPros.com
miklik
#3 Posted : Thursday, September 6, 2012 7:26:09 AM(UTC)
miklik
Check the power cord and they were fine. Pulled the inside door cover off and found that the switch leaf had broken off. I ended up drilling a hole through the front of the door to reattached the broken plastic tab and the switch leaf. I used a #6 nut and bolt. All good now.
#4 Posted : Thursday, September 6, 2012 2:25:22 PM(UTC)
I'm glad you did find the problem and your own way to fix it. Thank you for the feed back.
