2 Pages12>
Art Bans
#1 Posted : Tuesday, September 4, 2012 10:44:14 AM(UTC)
Art Bans
Washer runs for a few mins. then stops. Wait a few mins and it starts again for a min. or two. Repeats over on any cycle.(wash spin rinse)
Simon / APP Team
#2 Posted : Tuesday, September 4, 2012 1:03:21 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
You need to determine if this is the timer or the motor.
Wiggle the timer knob when washer stops. If it's starts right away-replace the timer.
Check if the motor overheats. Remove the pump from the motor, disconnect motor from the transmission and try it without the load.
The motor Part number: 661600
Part number: 661600
Use the video clip for the instructions.
Simon.
Art Bans
#3 Posted : Tuesday, September 4, 2012 3:20:31 PM(UTC)
Art Bans
:confused:
Originally Posted by: Simon / APP Team Go to Quoted Post
Hi.
Part number: 661600
Simon.
Art Bans
#4 Posted : Wednesday, September 5, 2012 6:18:43 AM(UTC)
Art Bans
:confused: I did what U said and it still does the same thing. start- stops! Wiggle timer, tap timer it still won't start. Wait a few mins. and it runs then stops. Art
Simon / APP Team
#5 Posted : Wednesday, September 5, 2012 11:31:10 AM(UTC)
Simon / APP Team
Groups: APP Team
Did you test the motor?
Simon.
Art Bans
#6 Posted : Wednesday, September 5, 2012 1:59:10 PM(UTC)
Art Bans
Simon.
I tested the motor on the floor unattached to transmission, and it did the same thing . (run- stop) The pump was aslo not on motor!:(
Simon / APP Team
#7 Posted : Wednesday, September 5, 2012 3:44:58 PM(UTC)
Simon / APP Team
Groups: APP Team
If the motor getting hot - replace it.
Simon.
Art Bans
#8 Posted : Wednesday, September 5, 2012 8:00:04 PM(UTC)
Art Bans
As I said B-4 the motor runs 4 a min then stops. Motor is not hot 2 touch, as it is on towel without pump on it and it stops after a min. of running. I hooked everything up to operate washer. I had low water level and it filled to that level and stated running 4 a min then stopped. I tried spin cycle,it didnot run. I waited 4 a min and it started 2 spin 4 a min. then stopped as usual. I noticed after several start stops that the dial on timer did not move where i placed it. Could this timer B defectived? Thank U 4 all the advice on trouble shooting this problem!!!:confused:
Simon / APP Team
#9 Posted : Thursday, September 6, 2012 7:08:16 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
First I'd replace the motor.If you'll get it from the APP you may return it even if it's been installed.
Simon.
Art Bans
#10 Posted : Thursday, September 6, 2012 9:13:15 AM(UTC)
Art Bans
The motor is not hot when it runs. My local sears has motor 4 $110, but will not take back if it does the same thing as this one! I also checked cap.for reliability and is was @199. I hooked everything back up and it filled 2 low water level & started up and quit in a min. waited and it ran and stoped, which it did over & over. The dial on timer did not move off where iI turned it to on wash or spin cycle. Could that B my problem? This machine is my wifes favorite and wants me 2 get it working as the new ones do not have the cycles she wants. I had hair B-4 this, now I look like Kojak! Thanks 4 all you help!:D
Guest (7)
Older Msytag top load washer main belt tension on model LA612 (Washer Repair)
by Guest 6/29/2024 10:22:44 AM(UTC)
Frigidaire dishwasher code A (Dishwasher Repair)
by Evandtam 6/27/2024 5:11:41 PM(UTC)
GE Top load washer not draining (Washer Repair)
by Guest 6/25/2024 4:59:12 PM(UTC)
Washer won’t spin with load (Washer Repair)
by Guest 6/25/2024 5:32:07 AM(UTC)
Samsung Top Load Washer (Washer Repair)
by welchjames65@hotmail.com 6/21/2024 3:08:07 PM(UTC)
Fisher Paykel Drawer Dishwasher will not Lock (Dishwasher Repair)
by thompsdw 6/17/2024 7:34:54 AM(UTC)
GFQ14 - Combination Washer / Condenser Dryer GFQ14ESSN0WW (Dryer Repair)
by SoakingWet 6/13/2024 10:48:53 AM(UTC)
GE Profile Washer not draining and water not hot (Dishwasher Repair)
by Guest 6/8/2024 9:00:21 AM(UTC)
Kenmore washer 110.81821110 (Washer Repair)
by Hitzemup 6/5/2024 3:57:12 PM(UTC)
LG Washer 0E (OE) Error After Pump Motor Replaced (Solved) (Washer Repair)
by kilimar 6/3/2024 2:34:22 PM(UTC)
Whirlpool duet washer front load (Washer Repair)
by Guest 6/3/2024 9:57:09 AM(UTC)
Kenmore 70 series washer grinding (Washer Repair)
by Higginsdog 5/28/2024 4:17:38 AM(UTC)
Dishwasher won't work. (Dishwasher Repair)
by Guest 5/23/2024 6:32:18 PM(UTC)
Kenmore 90 Series top-loader washer won't agitate/drain/spin (fixed?) and makes metallic noise (Washer Repair)
by deepdiver359 5/21/2024 8:09:21 PM(UTC)
GE washer grinding noise (Washer Repair)
by gefixin 5/20/2024 2:01:39 PM(UTC)
2 Pages12>
