KEVIN64
#1 Posted : Wednesday, September 5, 2012 11:05:56 AM(UTC)
KEVIN64
Oven Has No Power
#2 Posted : Thursday, September 6, 2012 2:37:15 AM(UTC)
Replacement parts for Whirlpool RBD305PDQ11 ELECTRIC OVEN | AppliancePartsPros.com
First check the power to the unit.
L1 to L2 should be 240 volts
If OK
If OK
Next check the thermal fuse (upper left in the wiring diagram).
This kills power to the transformer (Item 5 in Section 5 of the parts).
I cannot find it in the parts so you will have to call AppliancePartsPros.
Often they look like the following and are in the harness close to the control board or by the transformer.
Part number: AP3110028
Click on the picture for more info.
File Attachment(s):
RBD305.pdf (302kb) downloaded 8 time(s).
