My magic chef oven model#6498vrv is not maintaing proper temperature. I have replaced the oven sensor. Then checked oven temperature with a thermometer and temperature is off by 200-300 degrees. Last year I replaced the touch panel , which fine. I have searched for other parts that might be the problem, I found Relay board Part Number: AP379876 made by MAYTAG could this be needed? Any other suggestions or parts would be greatly appreciated. I'm sure there is a thermastat somewhere built into a part, could that relay board be it ? Thank You Michaelman31
Most likely the problem with your oven is a bad control board (aka clock). This is the part which operates with the relay board due the oven sensor readings. - The part number for the clock AP382949 - Here are the break down diagrams for the Magic Chef range Model 6498VRVGene.
Thank you Gene , is the thermastat in the control panel (clock) ? DO you have a wiring schematic? Thanks again for your help Michaelman
Your oven does not have any thermostats, just the control board.
Unfortunately I do not have the wiring diagram for your oven.
Thank you Gene.I will order the control panel .
Yes Gene is 100% correct on diagnosing the clock. Maytag (Magic Chef) clocks are known for going eratic in the temperature department.
