Hear noise from the rear of refrig. It appears to be the fan that pulls air across the coils, located bottom of refrig. Is this a major job to replace the fan and could the noise be from something else?? thanks for your help:
Here are your parts Replacement parts for TPX24PRYEW models | AppliancePartsPros.comYou will have to pull he unit away from the wall and remove the back cover to check the fan. On most units replacing the fan is not a difficult job. Be sure to clean the condenser coils while you have the unit apart. Also the vents on the rear cover and the front kick plate. |
THIS FORUM IS DEAD!!!!!!! |
