als1962
#1 Posted : Tuesday, September 4, 2012 7:54:02 PM(UTC)
als1962
After completing a self clean cycle, the oven no longer works. The \lower element is dead, on convection mode the fan runs but convection element is dead, the only element that works is the broil element. the rangetop works fine. I removed the lower element it looks ok and I get a reading of about 20 ohms with the ohmeter. I don't think it is the element, does anyone have any thoughts or ideas?
#2 Posted : Wednesday, September 5, 2012 2:42:02 AM(UTC)
I could not find any info on a A54.
Are you sure it is not an AS4.
Please check the model number.
als1962
#3 Posted : Wednesday, September 5, 2012 4:54:25 AM(UTC)
als1962
Yes I am sorry, it is an AS4.
#4 Posted : Wednesday, September 5, 2012 6:17:47 AM(UTC)
Here is the wiring diagram for this unit.
http://manuals.frigidaire.com/p...assomption/318046706.pdf
As you can see the bake and convection elements are controlled by the same repay on the control board.
If the unit stays in preheat then the board is the most probable cause.
If the oven shows that is is ready then the oven sensor may be the problem.
als1962
#5 Posted : Wednesday, September 5, 2012 12:58:07 PM(UTC)
als1962
Thank you for the suggestions den man. I am trying to understand the wiring diagram. So when I turn the oven on in the bake mode and set the temp to say 350 the temp shows in the display at 100 degrees ( must be as low as it goes) I can then hear a relay cycling it will click a couple of times and then silent for a minutes and then it cycles again but the temp of coarse never goes up beyond 100. So with that can we assume that the temp sensor is ok?
When you say the board may be the problem are you talking about the complete push button control panel? Are they not repairable?
I have fixed a few appliances in my day but this electronic controlled oven has got me a bit stumped. I do appreciate your expertise. Any further elaboration would be appreciated
#6 Posted : Thursday, September 6, 2012 2:21:26 AM(UTC)
[COLOR="Blue"]So with that can we assume that the temp sensor is ok?[/COLOR]
It does sound like the oven sensor is OK since it is trying to heat up but cannot for some reason.
[COLOR="Blue"]When you say the board may be the problem are you talking about the complete push button control panel?[/COLOR]
I cannot find a parts breakdown for this unit.
Some units use a control board and a control panel (keyboard).
Other units use a control board/timer that has the keypad.
It is the control board that is probably shot.
[COLOR="Blue"]Are they not repairable?[/COLOR]
Yes they are but getting the parts can be difficult.
Also manufacturers do not publish control board schematics so troubleshooting can be difficult.
In your case it is probably the bake relay on the board but may also be the electronics that control it.
You could Google "appliance timer repair". There are a number of companies out there that specialize in timer repair.
als1962
#7 Posted : Friday, September 7, 2012 11:48:34 AM(UTC)
als1962
Thanks again DEN MAN for all your help. I got the number off of my oven controller and checked it out online. Of course it was the one worth $550
I did some further checking and found a timer repair place on line and I called them. They will fix it for $129. He helped me further diagnosis it and your assumptions were correct. It is the Bake Relay that has failed. I removed it and mailed it to him today and should have it back in 10 days or so. Once again thank you for your advice.
Oven Will not heat to temp. (Oven Repair (including Ranges and Cooktops))
by rtmeek 9/12/2022 12:32:58 PM(UTC)
Frigidaire FEFL79HQA Oven Will Not Heat (Broil or Bake) (Oven Repair (including Ranges and Cooktops))
by Allen_M 5/19/2022 8:57:30 AM(UTC)
Frigidaire - Oven will not heat up but burners work (Oven Repair (including Ranges and Cooktops))
by JohnGuerra 3/18/2020 12:45:12 PM(UTC)
Frigidaire gas oven will not heat (Oven Repair (including Ranges and Cooktops))
by HHG 9/6/2019 11:33:44 AM(UTC)
GE Profile Oven will not heat past 100, broiler works (Oven Repair (including Ranges and Cooktops))
by maribernj 2/16/2016 8:37:13 AM(UTC)
Oven will not heat (Oven Repair (including Ranges and Cooktops))
by couldcareless 11/11/2015 2:05:29 PM(UTC)
by davidwhop 8/31/2014 7:17:47 AM(UTC)
Double Wall Oven will not heat up (Oven Repair (including Ranges and Cooktops))
by jwmingus 11/12/2013 4:25:40 PM(UTC)
Frigidaire Left oven will not heat either element (Oven Repair (including Ranges and Cooktops))
by morang 9/27/2013 5:08:44 PM(UTC)
Thermador sc302t top oven will not heat (Oven Repair (including Ranges and Cooktops))
by bnastasi 6/9/2013 9:01:10 PM(UTC)
Lower and Upper Oven will not heat (Oven Repair (including Ranges and Cooktops))
by Igmike 4/22/2013 5:43:12 AM(UTC)
My Oven will not heat up on bake (Oven Repair (including Ranges and Cooktops))
by missy79 4/3/2013 9:59:06 AM(UTC)
Electrolux dual fuel range oven will not heat (Oven Repair (including Ranges and Cooktops))
by p.andrew 3/19/2013 8:47:44 AM(UTC)
by Pjcibulski 1/29/2013 2:00:44 PM(UTC)
Oven Will Not Heat (Oven Repair (including Ranges and Cooktops))
by badams1214 1/18/2013 12:14:24 PM(UTC)
