eldonmac
#1 Posted : Monday, August 20, 2012 2:24:05 PM(UTC)
eldonmac
my top convection oven when temperture is reached will not quit heating up wheni try to turn oven off it keeps heating up then i have to turn breaker off the fan comes on and runs with no problem the lower oven works fine,I would like to know if you could tell me what parts I need to fix this thanks Eldon
#2 Posted : Monday, August 20, 2012 5:17:39 PM(UTC)
Hi Eldon,
Sounds like the problem is a bad upper oven relay board which is located on the right side behind the control panel.
- The relay board Part number: 74006613
