FPS
#1 Posted : 16 years ago
FPS
My diswasher is leaking from the bottom of the unit. The water connections are okay. The water appears to leak more during the rinse cycle.
The owner's manual contains a drawing of the water distribution system. It's not a very detailed drawing so I can't tell where the leak points may be.
Any advice on what may be causing the leak. If this is a leak between the pump and the motor is it worth fixing?
applianceman
#2 Posted : 16 years ago
applianceman
The rubber connector above the pump is a common leak point. The rubber sump behind the pump will leak often as well. If it’s leaking between the pump and the motor you can replace the seal. The seal is easy to install and I think it comes with good directions. Dishwasher Leaking Repair Guide
#3 Posted : 16 years ago
Leaks are usually worth repairing.
Remove the kick plate
Get yourself a small mirror and a good flashlight. A mirror on a handle like mechanics etc. use is a good option.
Remove power from the unit and dry the pump etc. with paper towels.
Start a cycle and find the leak.
Note that where it is dripping may not be where the actual leak is. It may be leaking higher up and then running down components till it drips off.
Watch where your hands are you do not want to get a shock. The shock probably will not be much but when you pull your hand out rapidly odds are high you would get a cut or scrape.
dishwasher leaking from bottom (Dishwasher Repair)
by kjack45 10 years ago
Hotpoint dishwasher leaking from bottom of motor (Dishwasher Repair)
by Beacon18 12 years ago
Dishwasher leaking from bottom middle of door (Dishwasher Repair)
by grayguy 14 years ago
Kitchenaid dishwasher leaking from bottom (Dishwasher Repair)
by smithguy 16 years ago
Dishwasher leaking from bottom of front door (Dishwasher Repair)
by kipper 17 years ago
