2 Pages12>
drremlap
#1 Posted : Tuesday, August 14, 2012 6:59:11 AM(UTC)
drremlap
MODEL KSRG25FKWH04
I think motor assembly is malfunctioning. I can take it out and reset it and it will make one batch of ice and will then call for more water and that water will come and it will freeze but not continue the cycle. I have done this many times and it always does one batch and then won't continue cycle.
#2 Posted : Tuesday, August 14, 2012 3:51:30 PM(UTC)
Looks like you have to order the new ice maker. It's not worth to repair the old one.
- The ice maker Part number: 2198597
drremlap
#3 Posted : Wednesday, August 15, 2012 7:25:55 AM(UTC)
drremlap
thanks - why not just AP4359694 - ice maker controle module with motor? wouldthat do it?
#4 Posted : Wednesday, August 15, 2012 1:58:16 PM(UTC)
You can try it but keep in mind that you will need to replace the thermostat too and you will have to order the alumilastic cement which must be used to attach the new thermostat. It will cost you all together $104.26 and the final result of such repair is not guaranteed because of low success rate on such repairs. On the other side for additional $18 you will get the whole new ice maker.
EMTPJ
#5 Posted : Wednesday, August 15, 2012 2:38:32 PM(UTC)
EMTPJ
^ +1 replace it all at once. Cheaper, and much easier to do. Piece of mind is well worth the extra $20
drremlap
#6 Posted : Monday, August 20, 2012 4:02:17 AM(UTC)
drremlap
HELP!! Bought and installed new icemaker -- NO ICE.... what else could it be? FRUSTATED!
#7 Posted : Monday, August 20, 2012 3:23:22 PM(UTC)
Does it do the same as the old ice maker did or there is something different?
drremlap
#8 Posted : Tuesday, August 21, 2012 4:08:57 AM(UTC)
drremlap
It Actually Does Nothing - So I Guess It's The Same .. Does Not Call For Water - So Nothing Happens At All
#9 Posted : Tuesday, August 21, 2012 12:57:20 PM(UTC)
Open the freezer door. Be sure the slide "on-off" switch on the right side is on. Check the LED on the right side.
Close the flipper door on the left side and check the LED again.
Post the results.
drremlap
#10 Posted : Tuesday, August 21, 2012 4:10:29 PM(UTC)
drremlap
When in ON position = top red light blinks two times, stops, blinks twice again, etc...
When in ON position = close flipper door on left side = red light stays steady and does not blink.
(FYI - the bottom light on right side never does anything..no red light, no blink)
THANKS
Guest (7)
Kenmore Standalone Ice Maker Stopped Making Ice (Refrigerator & Freezer Repair)
by ChadJ55 10/23/2023 5:40:08 AM(UTC)
Ice maker stopped making ice - appearswater in ice maker & making grinding (Refrigerator & Freezer Repair)
by Jamzona 2/19/2017 3:19:20 AM(UTC)
Ice maker stopped making ice, started making "owl hooting" sound (Refrigerator & Freezer Repair)
by Nerva 6/15/2015 10:39:34 AM(UTC)
MFX2571XEM1 Ice Maker stopped making ice (Refrigerator & Freezer Repair)
by jjones312 10/23/2014 2:34:32 PM(UTC)
ice maker stopped making ice (Refrigerator & Freezer Repair)
by robin Fisher 5/7/2012 6:34:53 PM(UTC)
2 Pages12>
