DebCarrigan
#1 Posted : Tuesday, August 14, 2012 12:39:23 PM(UTC)
DebCarrigan
My Kenmore HE3 Frontload washer stops and shows F and H codes in the countdown box. I have to pause and restart several times throughout a wash cycle. Once it gets past the stop at 24 minutes left it usually finishes the cycle without stopping.
#2 Posted : Tuesday, August 14, 2012 2:47:15 PM(UTC)
What is the complete model number of the washer?
DebCarrigan
#3 Posted : Tuesday, August 14, 2012 3:40:09 PM(UTC)
DebCarrigan
Kenmore HE3 Model 11045862400, Ser CSS2913334, type 199
DebCarrigan
#4 Posted : Tuesday, August 14, 2012 4:17:14 PM(UTC)
DebCarrigan
Not sure if this was sent the first time as internet went down just then.
#5 Posted : Wednesday, August 15, 2012 3:15:52 PM(UTC)
Perform the troubleshooting as described in the attached tech sheet for this error code. Post the results.
File Attachment(s):
Tech Sheet - 8182277 - HE3 - 11045862400.pdf (282kb) downloaded 12 time(s).
DebCarrigan
#6 Posted : Wednesday, August 15, 2012 4:23:12 PM(UTC)
DebCarrigan
How do we "verify pressure switch operation"
and "verify flow meter operation"
and "verify CCU operation"
All other checks seem to be functioning.
#7 Posted : Friday, August 17, 2012 4:16:16 PM(UTC)
"Verify flow meter operation" was followed by "...by blowing air through the part and measuring resistance".
Did you run the diagnostic test?
What about water in the washer?
