9133959
#1 Posted : Sunday, August 12, 2012 10:50:05 PM(UTC)
9133959
Microwave won't heat, all else functions normally. Change power setting and can hear unit cycling. No strange noises or odors. What all should I check, the process, and readings min/max. Unit is just over 5 yrs old. Any help would be appreciated. Thank you.
Simon / APP Team
#2 Posted : Monday, August 13, 2012 9:40:01 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Most likely the problem is bad magnetron
Part number: W10245183
Problem with Whirlpool electric range (won't heat properly anymore) (Oven Repair (including Ranges and Cooktops))
by phillydee 4/20/2023 6:10:35 AM(UTC)
New Kenmore Elite 796 Gas Dryer Won't Heat (Dryer Repair)
by Guest 12/26/2022 1:54:20 PM(UTC)
Whirlpool gas oven lights but won't heat to temperature (Oven Repair (including Ranges and Cooktops))
by mikepol2 10/28/2021 5:13:06 AM(UTC)
Whirlpool Duet Dryer won't heat anymore (Dryer Repair)
by Guest 3/31/2021 5:35:15 AM(UTC)
GE Microwave (JE1860BH04) won't heat AND table won't turn (Microwave Repair)
by CoryH 2/17/2021 6:45:11 AM(UTC)
Double Oven Won't Heat Back Up After Opening (Oven Repair (including Ranges and Cooktops))
by lamoureux.adam@hotmail.com 12/13/2020 11:44:10 AM(UTC)
Dryer won't heat consistently – Is an RCA model dryer actually GE? (Dryer Repair)
by OpsTao 12/11/2020 7:20:38 AM(UTC)
Maytag MGD9700SQ0 Won't Heat/Open Gas Valve (Dryer Repair)
by jpc315 11/9/2020 2:59:17 PM(UTC)
Samsung Dryer Won't heat no matter what I do (Dryer Repair)
by coachroy 10/16/2020 10:58:40 AM(UTC)
Whirlpool LGT7848AQ1 dryer won't heat (Dryer Repair)
by spiggman 9/19/2020 4:47:12 PM(UTC)
Maytag Dryer *usually* won't heat (Dryer Repair)
by ab52 6/12/2020 12:20:59 PM(UTC)
GE dryer runs but won't heat up (Dryer Repair)
by bristles 5/5/2020 5:44:54 PM(UTC)
GE Cafe CT9050SH1SS won't heat to desired temperature (Oven Repair (including Ranges and Cooktops))
by gvfixit 4/19/2020 3:22:33 PM(UTC)
Outside element in dual element won't heat, even after replacing (Oven Repair (including Ranges and Cooktops))
by RyanSha 9/2/2019 8:11:47 AM(UTC)
Kenmore Electric Wall Oven 790.41003603 - Broil AND Bake elements won't heat (Oven Repair (including Ranges and Cooktops))
by acehigh21 7/28/2019 11:14:25 AM(UTC)
