GWHIZ
#1 Posted : Friday, August 10, 2012 1:45:17 PM(UTC)
GWHIZ
I have a cabinet mounted microwave that is also an exhaust fan and the light over the stove. The microwave and exhaust fan work, however, the lights over the stove do not.
I have removed the bottom panel to access the wiring of the lights. Then, I found a connector. Upon disconnecting this connector, and using my multimeter I registered 7 volts on AC. It consistently read 7 volts when I pushed the button on the microwave's controls, to turn the "surface lights" on and off. With this, I am still clueless as to why the lights do not work even though they are receiving 7 volts of power.
Any assistance regarding this problem would greatly be appreciated. Thanks.
Simon / APP Team
#2 Posted : Friday, August 10, 2012 2:15:11 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
The model number you posted is for a dishwasher.
Please check and re post.
Simon.
GWHIZ
#3 Posted : Friday, August 10, 2012 2:35:22 PM(UTC)
GWHIZ
Sorry For The Wrong Model Number That Was Another I Had. Here Is The Model Number For The Hot Point Micr Model Is Rvm1425ba 003
Thanks Again
Simon / APP Team
#4 Posted: : Friday, August 10, 2012 2:59:58 PM(UTC)
Simon / APP Team
Groups: APP Team
When you are touching the light key is there any clicks or beeping?
Simon.
GWHIZ
#5 Posted : Friday, August 10, 2012 3:11:20 PM(UTC)
GWHIZ
When I press the light key there is a beep in addition to the display above the control panel that will say 'on' or 'off'. Thanks.
Simon / APP Team
#6 Posted : Sunday, August 12, 2012 6:52:37 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Most likely it's the control board Part number: WB27X10601
