Ejvtech
#1 Posted : Monday, August 6, 2012 6:41:49 PM(UTC)
Ejvtech
Had a power failure now the time does not display and dryer will not start. I can press the + or - keys on the control panel and i get a 1h through 10h on the display. Then I press the start button and it switches to 0:59 through 9:59 respectively. Not sure what this means. Do not get any error codes what so ever. Any help greatly appreciated.
Update: Put dryer into diag mode and getting F12 as error code which is no where to be found online or in the dryer manual. Help? Anyone? B)
Jbrew
#2 Posted : Wednesday, May 31, 2017 4:05:01 AM(UTC)
Jbrew
Having the exact same issue. Did you ever figure out how to fix it?
Thanks!
Ejvtech
#3 Posted : Wednesday, May 31, 2017 6:02:24 AM(UTC)
Ejvtech
Thanks!
Sorry no. Trashed dryer got a new one.
falkinm
#4 Posted : Tuesday, March 10, 2020 10:05:22 AM(UTC)
falkinm
I had the exact same issue, I found this in the technical service manual and luckily it worked for me.
Resetting the Modifiers and Options
to Factory Default
To return all options and modifiers to factory
defaults, select the timed dry cycle, then press
WRINKLE PREVENT, DAMP DRY SIGNAL,
within 5 seconds. When done correctly, the
7-segment display will show “Fd” and the
buzzer will sound before returning to Standby
Mode. This procedure does not return the
Customer-Focus
Guest
#5 Posted : Wednesday, May 3, 2023 5:12:35 AM(UTC)
Guest
falkinm Thanks a lot, you saved me !!
