I have a Frigidaire LTF7000ESO in the spin cycle will not work. All other wash modes work normally, except at the end "spin mode", it will not spin. The drain works fine. In looking through some of the forums, I discovered a suggested diagnostic test. I ran the test and I am getting error code: 59
Could you please tell me what this code means and what part I would need to fix it. Thank you in advance for your help.
Thank you for taking the time to reply. I performed test 10 and turned out I needed to replace the speed control board. Ordered the part and it was here in a day. Problem solved!!!!
You are welcome. We're glad you were able to fix it.
Thank you for the feedback.
So, I guess I jumped the gun a little. After replacing the part the washer worked perfect for about 10 loads. Now, its back to the same problem of it not completing the fast spin. Any further suggestions?
Sorry about it. Try to perform the same test and post the results.
