tnt4him
#1 Posted : Tuesday, July 24, 2012 6:22:42 PM(UTC)
tnt4him
Hi, My Maytag french door refrigerator stopped cooling. All the lights work, the digital readout says 0 and 38 but its rather ambient inside. There is no frost on the evaporator or cooling fins. The freezer is warm. the fan works and there is no water in the drip pan. The compressor motor hums and is warm to the touch. I read a blog that said the circuit board is the culprit but I am not sure. The blogger said that Maytag sent a free replacement circuit board but can you believe everything you read on the internet?
#2 Posted : Thursday, July 26, 2012 3:24:43 AM(UTC)
I doubt it is the board since your compressor is running.
Sounds like a sealed system problem.
I could not find any info on his unit.
Check your warranty, often the sealed system has a longer warranty than the rest of the unit.
You will need a pro for a sealed system problem and it can get expensive.
