ccfox
#1 Posted : Wednesday, July 25, 2012 12:51:03 PM(UTC)
ccfox
The Control Panel is beeping and the clock display is replaced with -F2-
Pressing the Set button stops the beep & returns the clock display but only for about 1/2 minute.
What is the F2 error code mean for this Gas Range?
Simon / APP Team
#2 Posted : Wednesday, July 25, 2012 1:54:19 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
The F2 code means over temperature.
Check the temp. sensor and harness. The resistance of the sensor at room temp. should be around 1100 ohm.
The temperature sensor Part number: Y0314907
Here are the breakdown diagrams and Replacement parts for Amana AGDS901E RANGE- S/C S/I DDRAFT GAS | AppliancePartsPros.com
Thank you. Post the results.
Simon.
F2 Error Code on GE Electric Oven (Oven Repair (including Ranges and Cooktops))
by Guest 9/11/2023 6:33:44 PM(UTC)
F3 then F2 error code on Whirlpool Oven (Oven Repair (including Ranges and Cooktops))
by Ed070811 11/10/2013 9:23:56 AM(UTC)
f2 error code while self cleaning (Oven Repair (including Ranges and Cooktops))
by sandyg 5/12/2013 2:35:23 PM(UTC)
Whirlpool F2 Error code. (Oven Repair (including Ranges and Cooktops))
by polk5295 3/29/2012 6:32:11 PM(UTC)
F2 error code (Oven Repair (including Ranges and Cooktops))
by DYB 3/19/2012 1:39:19 PM(UTC)
E1 F2 error code Kitchen aid biltin oven (Oven Repair (including Ranges and Cooktops))
by fredcroy 12/6/2011 2:19:31 PM(UTC)
E6 F2 error codes (Oven Repair (including Ranges and Cooktops))
by tom o 11/30/2011 6:37:15 AM(UTC)
f2 error code (Oven Repair (including Ranges and Cooktops))
by szawackitx 6/15/2011 7:46:39 PM(UTC)
Kitchenaid range f3 and f2 error codes (Oven Repair (including Ranges and Cooktops))
by shane1 5/24/2011 6:44:04 PM(UTC)
kenmore microwave has f2 error code (Washer Repair)
by bobval 4/29/2011 6:00:09 PM(UTC)
Please Help!! E6 and F2 Error Codes (Oven Repair (including Ranges and Cooktops))
by mlindsey3418 11/16/2010 1:27:25 PM(UTC)
E0 F2 error code (Oven Repair (including Ranges and Cooktops))
by carapet58 11/14/2010 1:33:19 PM(UTC)
by JennaLogan 1/15/2010 6:34:36 AM(UTC)
E6 F2 error code for Whirlpool double oven (Oven Repair (including Ranges and Cooktops))
by ddelay 1/2/2010 12:06:19 PM(UTC)
F2 error code (Washer Repair)
by kayakcrzy 10/20/2009 3:04:24 PM(UTC)
