hmslouie
#1 Posted : Saturday, July 21, 2012 1:50:15 PM(UTC)
hmslouie
Hello,
I have a Whirlpool Fridge Top Freeezer in which a Icemaker was
installed and cannot get the water to the ice tray to stop filling.
Returned the orginal icemaker and re-installed another and have
the same problem water fills the ice tray at a very fast rate and
will not stop. Icemaker does make ice correctly, but water flow
does not stop to tray. Responses are greatly appreciated.
Sean
#2 Posted : Sunday, July 22, 2012 4:49:14 AM(UTC)
Unplug the fridge.
If the water does not stop then the fill valve needs replacing.
maritime
#3 Posted : Monday, April 27, 2015 6:39:14 AM(UTC)
maritime
I have similar issue. Procrastinated in hooking up icemaker. Finally did and water won't stop flowing. Did you replace water valve and did that fix it?
