tigerjim
#1 Posted : Friday, June 29, 2012 8:17:42 AM(UTC)
tigerjim
An intermittent problem with the microwave sensing that the door is shut has now progressed to having to slightly depress door open button to get the unit to heat and turntable to turn. My question is twofold; 1) Is there an adjustment on the switch location that I can adjust? 2) If no adjustment fix and replacement is warranted, can I replace switch (AP2024337) safely without having to discharge the capacitor?
Regards,
Jim
Simon / APP Team
#2 Posted : Friday, June 29, 2012 11:04:39 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
When you remove the cover you will be able to determine if the switch bracket is adjustable or not. I recommend to check the upper interlock switch first and then the door sensing switch.
I also recommend you to discharge the capacitor (most of them has a resistor build in so no need to discharge).
Here are the breakdown diagram and Microwave replacement parts for General Electric JE1640WA01 Counter top microwave | AppliancePartsPros.com
Thank you.
Simon.
tigerjim
#3 Posted : Thursday, July 19, 2012 1:14:32 PM(UTC)
tigerjim
Thanks Simon for your response. I finally have taken microwave out of the wall and disconnected trim package. I then brought unit to my workbench and removed the cover to expose electronics and wiring. I then discharged the capacitor and checked the three door switches per troubleshooting guide enclosed within the case. The monitor and door sensing switches checked okay per ohmmeter, but the primary interlock switch remained open with micro switch pressed in or out and also with door closed it was open and per wiring diagram should be closed to complete circuit. The connector to that switch was a little discolored also like it had arced. Are there any other checks I shoul make while I have it apart?
Regards,
Jim
Simon / APP Team
#4 Posted : Thursday, July 19, 2012 2:42:14 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
At this point just replace the switch.
Simon.
tigerjim
#5 Posted : Tuesday, July 24, 2012 8:34:13 PM(UTC)
tigerjim
Originally Posted by: Simon / APP Team Go to Quoted Post
Hi.
Simon.
Well Simon thanks for the help, got the switch in today and microwave works and back in the hole with trim kit on. $14 switch saved me $$$$ that my wife wanted a convection microwave. Thanks again.
Regards,
Jim
Simon / APP Team
#6 Posted : Wednesday, July 25, 2012 1:01:44 PM(UTC)
Simon / APP Team
Groups: APP Team
My pleasure. Don't dive my info to your wife.
Simon.
