I have a Flap-door seal that needs replacing. It's edges have curled-up and no longer allows the door to close which allows cold air to leak out as well as ice/water droplets... I've found where I can get the parts but I need directions on how to get to do it. Can anyone help with this? The seal that needs replacing is part 30c in this diagram: ![UserPostedImage](http://i143.photobucket.com/albums/r131/dvanz19/Random%20Stuff/ScreenShot2012-07-15at122732PM.png) Also, just recently, the Ice Dispenser no longer releases Ice Cubes, it only releases Crushed Ice no mater which button you push. Any idea's? Is this something that is a simple parts replacement or should I call a repairman? fwiw, I am not experienced with these kinds of things but $$ is tight so I need to fix it on my own if I can... Thanks
Anyone have any thoughts on this??
Very difficult to give a proceedure for this. Just grab a chair and sit in front of it. Take the screws out and lift the sub panel up and tape it to the door while noting how all the parts are placed, then take everything out. Helps to have someone watch to verify how everything fits in place.
