i have checked the check value its working took bottom spray arm out it is getting water there and motor is turning but spray arms are not turning
Originally Posted by: ELETT1 ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) i have checked the check value its working took bottom spray arm out it is getting water there and motor is turning but spray arms are not turning i can take and add cup of water and it will turn the top spray arm but the bottom will still not turn or spray water
The system is designed to operate only one spray arm at a time. During the first wash and first and second rinses, only the lower spray arm operates. In the second wash, third and fourth rinses the spray arms alternate about every 90 seconds. You can learn how it works more detailed by reading the attached file. Gene.
