OK.. I got a call from my mother that her AC isn't cooling off the house. I have no errors on the furnace. The furnace appears to be wired properly, as well as the thermostat. What I am seeing, and what the diagrams read, When the furnace is heating the house, the relay sends the current to the blue wire, Medium/Low fan speed, and when Cooling, to the black wire for high speed. The furnace fan is only spinning one speed.. and I am assuming it's medium/low... From the diagram... I don't understand how the speed control of the fan happens. The SPDT relay sends the voltage to the blue wire, hence medium/low speed... and when cooling, the voltage is sent to the black wire, hence High speed. My question: Is the speed control in the motor? Blue wire medium/low and Black wire High... or is it in the relay... partial voltage to the blue wire, then the relay adds voltage to the black wire, sending voltage to both the black and blue wires for high speed?
Groups: APP Team
Hi.
While the AC is running pull the black wire off the control board (be very careful not to brake or short anything). If the blower stops - it's OK.
There are other things to check: first of all the freon pressure, the air filter. If you don't have the gauges touch the thick copper pipe - must be sweating and dripping condensation. If it's not - there is the sealed system problem.
When testing keep the FAU closed.
Thank you.
Simon.
When I took off the inspection cover, the copper coils on the ends had condensation, but nothing on the fins at all... Maybe it needs a shot of freon... guess I will have her call for a check-up. Thanks! Originally Posted by: Simon / APP Team Hi.
Thank you.
Simon.
Groups: APP Team
