I need a new part #K110 but the part is now different than the existing oart. The new part has a hos that is supposed to drain back into the wsher, but there is no vivible way to do it. What needs to be done to install the new part??
THIS FORUM IS DEAD!!!!!!! |
Originally Posted by: denman Thanks for the info.. The part is different than the part that is being replaced. It is my uinderstanding that this is the new replacement part. The new part has a hose attached to it. On a previous question from someone on the Repair Blob with the same question, the reply was that the hose goes back into the washer. My question is how do you achieve this?? Do I need to drill a hole in the door panel?? Your input is greatly appreciated.
I am not sure about this but it looks like there is not a seal at the bottom of the door. If not it probably just has to be routed to the bottom. With luck someone else will join in who has actually replaced the part. |
