AppliancePartsPros.com
Appliance Repair Help
Refrigerator & Freezer Repair
Amana SXD22S2W Not cooling enough. Ice buildup on evaporator at defrost thermostat
I have an Amana side by side refridgerator. It is no longer cooling properly. I took off the back panel and noticed ice build up at the top of the evaporator, primarily at the defrost sensor. I let the ice thaw out and plugged it back in. The ice reformed within an hour of being plugged in. Any help would be appreciated.
Check the compressor in the back, is it warm and vibrating and the condensing coils room temperarure?
Wondering if a solution was ever found, as it seems the same as the Whirlpool issue I'm having.
