AppliancePartsPros.com
Appliance Repair Help
Washer Repair
clothes wet after spin,does not seem to come up to full speed
several problems which may or may not be related. [LIST=1]
washer will begin agitating while filling.doesn't do this in pp cycle just regular cycle. is not spinning fast enough to dispense fabric softener and clothes are still wet at end of spin cycle. seems to add alot of water dring spin cycle.[/LIST]
The first and the third problems most likely caused by a bad timer. The second problem might be caused by an unbalanced load or the washer is not leveled properly. In that case it will shake a lot and never will go on the full speed. - The part number for the timer AP3139022 Gene.
Washer Repair
