AppliancePartsPros.com
Appliance Repair Help
Washer Repair
Washer won't spin or agitate, fills and drains ok
Washer fills and pumps water out. Electrical controls seem to work. It does not spin or agitate at all. One suggestion was to bypass the magnetic control on the lid, which we did but it didn't help.
Remove the front cover. Check the in line fuse for continuity. The location of the fuse is shown in the attached file. - The fuse kit Part number: WH49X10055
If the fuse is bad, will anything else need checked?
I've tried the you tube tests.. Blew in the small tube up to the size of the load nozzle and can hear the clicks... Even did the motor reset with unplugging and opening the lid 6 times... Actually worked last month when this happened but not this time.. I read checking a fuse line.. Do I have to u wrap the tape or just look if it's bent? Washer is only 6 years old...
Washer Repair
