adsch
#1 Posted : Tuesday, June 26, 2012 7:55:27 PM(UTC)
adsch
My Whirlpool gas dryer will not work when pushing start. I have checked power coming in, door switch, and thermal fuse. I am wondering if it could be the timer. When checking W (white wire) and T (tan wire) coming into the timer on the back of the dryer with those wires disconnected from timer and dryer unplugged I get no reading except (L open). Shouldn't that be reading atleast 0.00 or something. Please help ...the timer is $100 and not sure how else to test it or maybe jump it to check to see if that is it.
allen9258
#2 Posted : Wednesday, June 27, 2012 7:27:53 AM(UTC)
allen9258
be sure to check your push to start switch hope this helps
adsch
#3 Posted : Wednesday, June 27, 2012 9:53:22 AM(UTC)
adsch
I am sorry, forgot to mention. I did test and according to schematics is fine and showing correct continuity.
Simon / APP Team
#4 Posted : Wednesday, June 27, 2012 10:36:37 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
With the door switch and timer contacts BK- BU, T-W closed the dryer should start.
You may jump timer contacts to check if it will work.
If that is not the timer you have a bad motor.
Here are the breakdown diagrams and Replacement parts for Whirlpool WGD5540SQ0 29"GAS DRYER | AppliancePartsPros.com
Good luck. Post the results.
Simon.
adsch
#5 Posted : Saturday, June 30, 2012 6:03:24 AM(UTC)
adsch
Thank you Simon,
It was the timer. To double check, we jumped as per your suggestion and then were sure that was it. Ordered the part from Appliance Pros (since local supplier was on backorder) installed this morning and dryer is running great!
Simon / APP Team
#6 Posted : Monday, July 2, 2012 10:16:56 AM(UTC)
Simon / APP Team
Groups: APP Team
You are very welcome.
Simon.
Whirlpool Dryer Won't Start (Dryer Repair)
by agjr200hp 2/5/2017 5:36:21 AM(UTC)
Whirlpool Dryer Won't Start- Help! (Dryer Repair)
by NikTy15 5/3/2015 6:59:24 AM(UTC)
Whirlpool dryer won't start (Dryer Repair)
by cmarley304 8/19/2014 6:07:34 PM(UTC)
by jdbell1114 3/17/2014 5:58:20 PM(UTC)
by emontoute 8/4/2013 10:01:22 AM(UTC)
by Turtleman1961 1/18/2013 5:52:20 PM(UTC)
Whirlpool Dryer won't start - buzzing (Dryer Repair)
by David Mitchell 1/14/2012 11:52:35 AM(UTC)
by gunworks 12/14/2011 6:47:15 PM(UTC)
by patarnotte@comcast.net 12/6/2011 1:57:13 PM(UTC)
Whirlpool Dryer won't start, but hums (Dryer Repair)
Belarus gmreeves2 12/1/2011 8:16:57 PM(UTC)
by JWCL 11/29/2011 6:43:51 AM(UTC)
by moonie777 5/13/2011 8:59:04 AM(UTC)
by zebra47cb 2/24/2011 2:53:01 PM(UTC)
Whirlpool Dryer won't start in dryer mode. (Dryer Repair)
by hol99 12/24/2010 1:06:56 PM(UTC)
by hol99 12/15/2010 8:39:33 PM(UTC)
