Chad993
#1 Posted : Tuesday, June 26, 2012 7:50:53 AM(UTC)
Chad993
My Frigidaire washer will not stop filling of water. I have replaced the switch Pressure for water level. but still the same thing.
Simon / APP Team
#2 Posted : Tuesday, June 26, 2012 3:46:18 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Turn the washer to fill and then unplug it. If the water still coming into the washer - replace the water inlet valve.
If it stops - check the air pressure hose for cracks and holes.
They call it Chamber Part number: 134369900
Here are the breakdown diagrams and Replacement parts for Frigidaire FWFB9200ES0 Frigidaire/washer | AppliancePartsPros.com
Thank you. Post the results.
Simon.
Chad993
#3 Posted : Friday, June 29, 2012 8:29:46 AM(UTC)
Chad993
that hose does not leak air or water.
Simon / APP Team
#4 Posted : Friday, June 29, 2012 9:51:44 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
If the water stop filling in when you unplug the washer check the wire harness from the pressure switch to control board, check all the connectors at control board.
If all checks fine - replace the control board.
Control board Part number: 137006000
Washer will not stop filling with water (Washer Repair)
by abcps 10/5/2012 11:47:06 AM(UTC)
washer will not stop filling (Washer Repair)
by limey 6/5/2012 9:03:58 PM(UTC)
washer will not stop filling with water. (Washer Repair)
by Louis.nicholls 12/27/2011 8:34:31 AM(UTC)
washer will not stop filling with water (Washer Repair)
by lgoodpaster 10/13/2011 4:37:28 AM(UTC)
Maytag heavy duty washer will not stop filling up (Washer Repair)
by john rodriguez 9/25/2011 11:10:43 PM(UTC)
Washer will not stop filling automatically (Washer Repair)
by rickeystu2 5/28/2011 6:23:39 PM(UTC)
Dishwasher will not stop filling. Leaking on floor. (Dishwasher Repair)
by mpickell 11/15/2010 7:19:31 PM(UTC)
Washer will not stop filling (Washer Repair)
by TOM901 1/13/2010 1:44:04 PM(UTC)
Washer will not stop filling/overflowing (Washer Repair)
by TASALAIZ 6/9/2009 12:26:04 PM(UTC)
Washer will not stop filling and tub leaks (Washer Repair)
by t7433 3/12/2008 11:41:49 AM(UTC)
by Mwaters583 10/26/2007 7:37:58 AM(UTC)
