timmykang
#1 Posted : Saturday, June 23, 2012 12:21:08 PM(UTC)
timmykang
My dryer won't start, I omed out every relays and thermal switch, but cannotfind what's bad.
#2 Posted : Sunday, June 24, 2012 4:31:06 AM(UTC)
Here are your parts, includes a wiring diagram.
Replacement parts for Maytag PYE2300AYW DRYER- ELE | AppliancePartsPros.com
Have you checked the power?
Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker.
Check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
Do this with the heater off and on.
If the power is good then unplug the unit and attach/tape one meter lead to the Neutral on the power cord plug and leave it there. Now work your way back through the motor/start circuit till you find the open.
Maytag dryer won't start (Dryer Repair)
by eagle243 11/15/2017 6:44:39 PM(UTC)
Maytag Dryer won't start when hot (Dryer Repair)
by MrFrisco 12/9/2012 5:58:05 PM(UTC)
by crmullins 7/9/2012 9:36:41 PM(UTC)
Maytag Dryer won't start (Dryer Repair)
by tmckeithan 11/30/2011 5:07:47 PM(UTC)
by cah14522 2/10/2011 2:43:44 PM(UTC)
by ssp123 2/11/2010 3:23:28 PM(UTC)
Maytag dryer won't start- thermostat question? (Dryer Repair)
by Underdog 1/30/2010 4:43:58 AM(UTC)
Maytag dryer WON'T START ! (Dryer Repair)
by souptafied 5/22/2009 4:25:25 PM(UTC)
Maytag dryer won't start....... (Dryer Repair)
by ShaNene 3/4/2009 8:40:55 AM(UTC)
Maytag dryer won't start Help!!!! (Dryer Repair)
by Dwatts 11/17/2007 9:54:55 AM(UTC)
