Guido
#1 Posted : Friday, June 22, 2012 9:40:34 AM(UTC)
Guido
The refrigerator was moved to a new location, and a new water line connected. The ice maker made ice, but, has now stopped. The water dispenser provides 16 oz of water in 15 seconds.
I cycled the control arm of the ice maker up and down several times. I removed the plastic cover from the front of the ice maker, and observed that the gear is not moving, and the arm is staying down. Is there any way on this ice maker to check with a jumper wire to see if the gear can be made to move?
Their is also no water coming to the ice maker from the valve. This I observed by checking the tube from the valve up to the ice maker.
I poured some water into the ice maker, and it produced a few small cubes. I tried again, and nothing was produced.
Any more checks I can do to pinpoint the problem part, or, do you feel it is either the ice maker, the valve, or both?
Simon / APP Team
#2 Posted : Friday, June 22, 2012 12:46:07 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
What is the temperature in the freezer?
Using the multimeter check for 120v at the icemaker plug.
Post the results.
Simon.
Guido
#3 Posted : Saturday, June 23, 2012 6:54:56 AM(UTC)
Guido
Originally Posted by: Simon / APP Team Go to Quoted Post
Hi.
Post the results.
Simon.
Temp is zero degrees F
115V is at the ice maker plug
Simon / APP Team
#4 Posted : Sunday, June 24, 2012 6:00:17 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Switch around the electrical plugs at the water inlet valve and press the lever at the dispenser. If the icemaker fills with water - replace it.
If not - replace the water valve.
Please provide the complete model number for the correct part number.
Thank you.
Simon.
Guido
#5 Posted : Monday, June 25, 2012 6:58:11 AM(UTC)
Guido
Hi.
Thank you.
Simon.
Simon,
I did as you suggested, and, the ice maker filled with water! So, I will order the ice maker.
Thanks for your help!
Guido
Simon / APP Team
#6 Posted : Monday, June 25, 2012 11:02:14 AM(UTC)
Simon / APP Team
Groups: APP Team
You are welcome.
Simon.
Guest (8)
Ice Maker Not Making Ice At All Times (Refrigerator & Freezer Repair)
by danrclem 6/11/2023 6:52:52 PM(UTC)
Whirlpool WRF535SMBM00 Ice maker not making ice (Refrigerator & Freezer Repair)
by Derek Halter 3/7/2023 12:03:25 PM(UTC)
LG Refrigerator LFX21960ST Ice maker not making ice (Refrigerator & Freezer Repair)
by tfmc369 9/19/2022 9:02:45 AM(UTC)
Under Counter Ice Maker not making ice (Refrigerator & Freezer Repair)
by ling_appliance 3/13/2022 5:55:41 AM(UTC)
FRS26KF6EM4 Ice Maker not making ice (Refrigerator & Freezer Repair)
by johnhurst 9/3/2021 10:14:18 AM(UTC)
Maytag ice maker not making ice, I don’t know what else to try... (Refrigerator & Freezer Repair)
by Karnsky 12/11/2020 5:09:39 PM(UTC)
Whirlpool Ice Maker Not Making Ice (Refrigerator & Freezer Repair)
by hanginghelmet 5/8/2016 2:24:52 PM(UTC)
Whirlpool Ice Maker not making ice (Refrigerator & Freezer Repair)
by turbotribes 8/1/2015 9:44:31 AM(UTC)
by kidmims 7/25/2015 9:41:54 AM(UTC)
Ice Maker not making Ice. (Refrigerator & Freezer Repair)
by atticus1 6/11/2015 5:28:24 PM(UTC)
by gaff 11/13/2013 7:29:05 PM(UTC)
Ice maker Not making ice (Refrigerator & Freezer Repair)
by chavisfamily1234 11/2/2012 8:52:20 PM(UTC)
by cgoodwin 8/2/2012 11:07:55 AM(UTC)
Kenmore Ice Maker not making Ice (Refrigerator & Freezer Repair)
by ghauptman 5/25/2012 1:47:12 PM(UTC)
Kenmore ice maker not making ice (Refrigerator & Freezer Repair)
by rswareing 5/4/2012 8:49:05 AM(UTC)
