allen9258
#1 Posted : Thursday, June 21, 2012 8:08:10 PM(UTC)
allen9258
Ok this is my problem as best as i can explain it this washer will spin but after a while the motor seems to over heat and stop it will start up fast then it will slow down and stop before the spin cycle is complete after it stop then it will not start up until it has had time to cool off even then it will not just start to spin some times unless you spin the tub by hand then start the spin cycle any ideas as to just what the problem or problems could be?
CharlesThompson
#2 Posted : Friday, June 22, 2012 12:28:05 AM(UTC)
CharlesThompson
I think there must be an issue with a motor. I think the coppor wires get damaged and hence it is getting heated and stop due to heat. You need to check the motor first.Quality kitchen cabinets
allen9258
#3 Posted : Friday, June 22, 2012 6:24:17 AM(UTC)
allen9258
how would you recommend that i check the motor and test it for what meaning just replace it or run a series of test to determine if its bad if it needs testing i need the procedure to test it or how to go about it
