Kipster28
#1 Posted : Wednesday, June 20, 2012 2:06:34 PM(UTC)
Kipster28
I have a Frigidaire front load washer that stopped working. I replaced the door lock mechanism as it seemed with a lot of issues that I read on here it could be the issue. It still doesnt work and the only thing I get on the display panel even though I have unplugged it is the the right side column of lights is lit up all except the Door Lock light. Any ideas?
#2 Posted : Thursday, June 21, 2012 2:38:40 PM(UTC)
Perform the troubleshooting as described in the Tech sheet and post the results.
Here are the breakdown diagrams and Replacement parts for Frigidaire FTF2140ES1 Frigidaire/washer | AppliancePartsPros.com
Kipster28
#3 Posted : Thursday, June 21, 2012 3:33:47 PM(UTC)
Kipster28
When I try to do the error check only four of the five lights come on. None of them flash. The Door Lock is the light that doesnt come on. When I hit the Pause Cancel button the lights dont disappear. They flash and beep three times and go back to the light display as originally detailed. Door Lock light is off and the rest are lit.
Kipster28
#4 Posted : Thursday, June 21, 2012 3:59:31 PM(UTC)
Kipster28
Thanks for your help Gene.. After trying the diagnostics again I was able to figure out it had somehow got switched into Factory settings/. For some reason unplugging it did not switch it back on its own. Thanks again!
