I believe I need to replace the magnetron. Can someone direct me to some directions on how to get at it. I need some directions before I purchase a new one.
The microwave shuts down in 3 sec , but if I put it a 0 power it will run forever. I read here that it may be RF leakage from the magnetron
Thanks for your help MikeB.
Hi Mike, You have to remove the microwave from the oven cabinet first. The instructions are attached to the reply. - The magnetron Part number: 4375072
OK, so the symptoms are: microware runs and heats for 3 sec and then shuts off as if the door was opened. If the microwave is on 0 power, it will run forever. It is only when the magnetron kicks in that the unit will turn off
I replaced all 3 door switches and the magnetron. I checked the magnetron thermal switch and it is good. I am tired of throwing parts at this thng, but what else could it be. Next I was going for the capacitor. Any help would be appreciated.
MikeB.
Groups: APP Team
Hi.
Did you check if the magnetron fan is working?
Also, check the cavity and magnetron thermal fuses when the microwave stops working. If everything check out OK - then most likely it's the relay in the control board.
Thank you.
Simon.
Simon - Thanks for the reply. Yes, the blower motor is working. I did verify the magnetron thermal cut-off is working (actually cuts off at about 170F - 180F Vs the 145F per spec). I did not verify the cavity thermal cut-off.
What would cause the relay to cut out? Most relays will fail to pick or fail to release. In this case, it will pick for 3 sec and then release.
Also, it seems that after I have worked on the unit, when I first power it up, all is good. I have run the unit for 10 mins w/o any issues (I put a few cups of water water in the microwave and it heats up just fine) It is the next day that it starts acting up again.
Thanks MikeB.
