Here are your parts. Section 3 will help you see how the door is put together.
Replacement parts for Frigidaire FEF365BWF Frigidaire/electric Range | AppliancePartsPros.comRemove the door from the unit.
The operators manual shows how to do this.
Just in case you do not have it, you can download it here.
http://manuals.frigidaire.com/p...ingfield/316257123en.pdfOven Door Disassembly
Removing the upper door trim:
1. Remove the oven door and lay it on a flat surface. Put a couple towels or a blanket under it.
2. Remove the two screws holding the trim to the inner liner.
3. Slide the trim off the top of the door
Door handle:
1. Remove upper door trim.
2. Remove the two screws holding the door handle to the upper door trim.
Outer door glass and trim:
2. Remove the four screws at the bottom holding trim to the inner door liner, and lift the glass and trim off.
Center glass:
1. Remove the outer door glass and trim.
2. Remove the eight screws, four from each, holding the top and bottom center glass trims.
3. Remove the trims and lift the glass off.
Wool shield:
1. Remove the center glass.
2. Remove the six screws, two at the bottom and two on each side, holding the wool shield to the inner liner and slide the wool shield up and off.
Glass package and inner door liner:
1. Remove the wool shield. The glass package can now be lifted out.
2. With the glass package removed, the door seal, insulation and the inner door remain.
