ttomasko
#1 Posted : Tuesday, June 12, 2012 5:57:37 PM(UTC)
ttomasko
I noticed water dripping from upper top of refrigerator section dripping onto top refrigerator shelf.
The freezer pan(bottom section of freezer and drain tube is freezing up.
Upon defrosting refrigerator:
Drain tube was/is clear
Freezer heater element measures 33 Ohms
Heater voltage (with heater disconnected) reads 22VAC when defrost timer shuts off compressor
Heater Voltage(with heater disconnected) reads 27VAC when defrost timer allows compressor to run
What to do next????
Simon / APP Team
#2 Posted : Tuesday, June 12, 2012 7:01:43 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Normally the voltage at the defrost heater should be 120VAC.
If you are getting 22 - 27VAC then the problem is within the defrost timer (control board) or the wire harness between them.
For more accurate part numbers and diagrams please check the model number. The one you provided doesn't come up.
Thank you.
Simon.
ttomasko
#3 Posted : Tuesday, June 12, 2012 8:13:20 PM(UTC)
ttomasko
Sorry I put an extra letter in model number correct Model Number should be
ET1MTKXKQ07
I also have become aware that I need to check heater voltage when bimetal thermostat is at freezing temp. It was not, when I got the readings of 22 & 27 VAC
Tom
Simon / APP Team
#4 Posted : Wednesday, June 13, 2012 10:10:18 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Check the bi-metal and if it's closed at freezing temperature - replace the defrost timer.
The timer Part number: 482493
Part number: 482493
The bi-metal Part number: 4387503
Thank you. Post the results.
Simon.
richappy
#5 Posted : Thursday, June 14, 2012 3:08:49 AM(UTC)
richappy
More convenient and a better test, to just temporarily short the wires to the defrost thermostat, then check for defrost action.
#6 Posted : Thursday, June 14, 2012 3:34:03 AM(UTC)
Replacement parts for Whirlpool ET1MTKXKQ07 TOP-MOUNT REFRIGERATOR | AppliancePartsPros.com
You may want to back up a bit in your troubleshooting.
Why are you looking at the defrost parts in the unit?
When you removed the evaporator cover to check the drain were the coils iced/frosted up to the point where the evaporator fan could not pull air through them?
If they were just lightly frosted then you probably do not have a defrost problem.
Also if you have a defrost problem the compressor will run pretty well continuously as the freezer tries to reach set point but cannot cool down efficiently because air is not being circulated through the coils.
If when you saw the dripping the compressor and fans were off then it may well have been water from the defrost cycle and you just had a frozen or partially clogged drain.
jason808
#7 Posted : Sunday, November 3, 2013 1:20:09 AM(UTC)
jason808
ttomasko, what did was the problem and how did you fix it? thanks
atajalo
#8 Posted : Friday, August 25, 2017 9:05:11 PM(UTC)
atajalo
Originally Posted by: Simon / APP Team Go to Quoted Post
Hi.
Part number: 482493
Simon.
Simon, I have the same problem but with a GE GSS201EMD side by side refrigerator. The bimetal test good and only have about 30 volts AC at the heater terminals. Also, the heater is open/burned.
Please help
Thanks, Gabe
