DRRICK
#1 Posted : Tuesday, June 12, 2012 8:04:00 AM(UTC)
DRRICK
MY WIFE WAS CLEANING THE STOVE TOP. IT STARTED TO HAVE A SLOW CLICK KIND OF LIKE THE CLICK IT MAKES WHEN YOU LIGHT THE BURNER BUT NOT AS FAST. I UNPLUGGED THE STOVE AND TOOK THE TOP OFF. I PLUGGED IT BACK IN AND IT STILL DID THE SLOW CLICK. WHEN I TRIED TO LIGHT THE BURNER THERE WAS ARCING IN THE BLOCK WHERE THE WIRES GO IN AND OUT TO THE BURNERS. SPARK MODULE. PLEASE LET ME KNOW IF THE SPARK MODULE IS BAD OR WAS SOMETHING DONE WHEN IT WAS CLEANED. THANK YOU::confused:
Simon / APP Team
#2 Posted : Tuesday, June 12, 2012 8:45:37 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
If the spark module doesn't work, then replace it.It's very difficult find the exact reason of the failure.
The spark module Part number: WB13K5078
DRRICK
#3 Posted : Tuesday, June 12, 2012 8:57:30 AM(UTC)
DRRICK
Thank You Simon
Does The Slow Clicking And Arcing In The Spark Module Mean The Spark Module Is Bad? Or Because Of Trying To Clean It May Have Damaged An Electrode?
DRRICK
#4 Posted: : Tuesday, June 12, 2012 9:33:17 AM(UTC)
DRRICK
Also, When I Tried To Light The Burners And It Was Arching In Th Spark Module I Didnt Have The Electrodes Hooked Up. Could That Be Why It Was Arching Thru The Spark Module?
Simon / APP Team
#5 Posted : Tuesday, June 12, 2012 10:35:26 AM(UTC)
Simon / APP Team
Groups: APP Team
You have to put everything back together before checking it.
Let it dry for a day or two then try again. There is a good chance that it will be OK.
Thank you.
Simon
DRRICK
#6 Posted : Tuesday, June 12, 2012 11:11:17 AM(UTC)
DRRICK
:) Thank You Simon. Will Give It A Day To Dry Out.
Simon / APP Team
#7 Posted : Tuesday, June 12, 2012 7:48:13 PM(UTC)
Simon / APP Team
Groups: APP Team
You are welcome.
Simon.
GE gas stove PCGS930SEL2SS (Oven Repair (including Ranges and Cooktops))
by dev61 9/27/2021 3:57:09 AM(UTC)
Ge Gas Stove Top shorted out (Oven Repair (including Ranges and Cooktops))
by Blue2016 2/12/2016 7:20:44 AM(UTC)
GE gas stovetop will not ignite (Oven Repair (including Ranges and Cooktops))
by yenpta 11/14/2012 11:54:04 AM(UTC)
Another GE gas stovetop ignitor problem (Oven Repair (including Ranges and Cooktops))
by Jeffdzz 11/4/2011 6:49:24 PM(UTC)
GE gas stove broiler and top burners work, but alas, no oven (Oven Repair (including Ranges and Cooktops))
by pschutte 4/21/2009 7:26:06 AM(UTC)
GE Gas Stove broiler works but oven wont light (Oven Repair (including Ranges and Cooktops))
by dunndec 1/27/2009 2:50:30 PM(UTC)
